Audirvana Plus 3 integrates MQA decoding
Audirvana Plus 3, announced at CES 2017, is the first audiophile player that integrates the MQA Core Decoder, enabling:
  • MQA capable audio devices to benefit from the complete MQA audio quality. In this case Audirvana Plus continues to bring the strongly audible Sound Quality improvement of its optimized audio engine.
  • Non MQA capable audio devices to benefit from the high resolution (doubled sample rate compared to the encoded file one) thanks to the MQA decoder integrated in Audirvana Plus 3. In this case, Audirvana Plus brings, in addition to the general Sound Quality improvement, the decoding of the MQA file that would be played only at little above CD quality otherwise, losing all its high resolution benefits.
Any MQA file (in FLAC, or other container) will benefit from Audirvana Plus 3 decoder, whether it is in the local library, or read from a streaming service such as TIDAL master.
What is MQA?
MQA is a revolutionary end-to-end technology that delivers master quality audio in a file that’s small enough to stream or download. What’s more, it’s backwards compatible, so will play on any device. And because it’s fully authenticated, you can be sure you’re hearing exactly what the artist approved in the studio.
The price in euro may be increased to follow the EUR/USD exchange rate variation.
For those who are attending CES, pay attention to the Macs demoing MQA, you will see the pre-release of Audirvana Plus 3 in action:
1 reply
Trackbacks & Pingbacks
  1. […]    macOS 向けの音楽再生アプリケーション「Audirvana Plus」の最新バージョン「Audirvana Plus 3」が、2017年1月末にリリースされます。最新バージョンでは、新たに「MQA(Master Quality Authenticated)デコーダー」を搭載。これにより、「MQA(Master Quality Authenticated)」に対応していない USB DAC で視聴しても、アプリケーション側で「MQA(Master Quality Authenticated)」へと圧縮されたデータを視聴できるようになります。   なお、価格は新規ユーザーは $79。従来のユーザーは、$39 でアップグレードが可能です。また、TIDAL が新しく開始した MQA(Master Quality Authenticated)音源「TIDAL Masters」プランにも対応するものの、日本でのサービス展開が行われていないため、TIDAL を利用したい場合は海外などで取得したアカウントが必要になります。    ちなみに、「Audirvana Plus」は、Hi -Res(ハイレゾ)音源や DSD 音源を再生し、通常音源なども高音質で再生できるアプリケーションです。対応するファイル形式は、WAVE、AIFF、Apple Lossless、FLAC、WavPack、APE、Cue Sheets、M4A、MP3、DSD になります。2017年は、アプリケーション・ハードウェアともに 「MQA(Master Quality Authenticated)」に対応するものが多くなってきています。今回、この「MQA(Master Quality Authenticated)って何?」という方も多いと思われますので、こちらの記事を参照してください。簡単にですが説明しています。   […]
Comments are closed.
