How to install Audirvana Plus for Windows 10 ?
Discover how to activate Audirvana Plus for Windows 10 on your PC
1 – How to download the Trial Version ?
In order to get the 15 days free trial version, click on the following “Download Trial Version” button.
  • You accept the terms of the License Agreement and you could click on “I fully agree with the above terms and Download Now” at the bottom of the Download Page. The download will then start. Once the download is complete, you will find an .exe file in your “Downloads” folder.
  • You do not accept the terms of the License Agreement and you could click on the “I disagree” at the bottom of the Download Page and come back to Audirvana Homepage.
2 – How to launch the setup.exe file ?
After clicking on the file “setup.exe”, Audirvana Plus for Windows 10 is being installed on your PC.
Once the installation completed, you will find the Audirvana Plus icon on your desktop. You could then double click on the application icon to to launch it.
Special Remarks:
  • You may receive a Windows Smartscreen warning because it is a brand new application for Microsoft.
  • If you did not install .Net 4.7.1, your PC may request to restart to complete the installation.
  • If you can not install Audirvana Plus on your PC, you can go to Windows Security> Center Settings, Virus and Threat Protection, Ransomware Protection, and disable controlled access to files (even momentarily).
3 – How to activate your Trial Version ?
Click on “Request Trial” button. Audirvana Plus for Windows 10 will then launch.
In order to import your music and get the connection with your hires Streaming Services, do not hesitate to watch the following Tutorial Video.
4 – Quick Start Guide of Audirvana Plus for Windows 10
5 – How to import your music in Audirvana Plus for Windows 10 ?
To import your music into Audirvana Plus for Windows 10, do not hesitate to watch attached video.
You can import your music from your local files or directly from the hires Streaming Services:
  • TIDAL
  • Qobuz
  • HRA-Streaming
6 – How to activate your license key Audirvana Plus for Windows 10 ?
You have been happy using the trial version during the 15 days free trial and you would like to purchase a license key of Audirvana Plus for Windows 10.
Note that the license key could be activated on two PC computers :
  • for your exclusive use
  • and not running simultaneously.
The license key cannot be registered on a PC computer if the trial version has not been installed previously.
