EQ and Effects
The use of an external filter, or audio plug-in, modifies the frequency response of all songs played. This can be useful to correct room resonance, change the signature of an audio system, or apply a specific effect. Audirvana can integrate AudioUnits under macOS, or VST3 under Windows, into the signal processing chain. Set the compatible filters of your choice and apply them to all songs played in Audirvana. These settings should be carefully used and are not for everyone. They require expertise to avoid creating greater nuisances than those you were trying to correct in the first place.
How to install a VST3 plugin and use it in Audirvana?
1) Download (1) and launch (2) the latest version of the plugin from the plug-in creator’s website. We take as an example the SonEQ from Sonimus, available free of charge by clicking here:
Soneq Download
When installing the plugin, simply click on next until you reach the step of selecting the plugin version and select the 64-bit VST3 version of the plugin (3). You can then click on next until the installation is complete.
Start Audirvana and then go to the settings of your audio system (4 and 5).
In the “Audio Signal Processing” section, you must activate the VST3 plugins, then you can select your plugin (6) and configure it (7). You can enable the real-time control option to configure your plugin while listening (8 and 9). We recommend that you use this mode to set your correction and then disable this option to get the best possible rendering quality.
The standard for plugins on MacOS is the Audio Unit (AU).
How to install an AU plugin and use it in Audirvana for MacOS?
Soneq Download
When installing the plugin, simply click on next until the installation is complete.
Start Audirvana and go to your audio system settings (3 and 4).
In the “Audio Signal Processing” section, you must activate the Audio Unit plugins, you can then select your plugin (5), if you do not see your plugin in the list a restart of your Mac will be necessary.
You can configure your plugin without listening to music (6).
You can also enable the real-time control option to configure your plugin while listening (7 and 8). We recommend that you use this mode to set your correction and then disable this option to get the best possible rendering quality.
This website uses cookies to ensure you get the best experience.
