New iTunes 12.4.0.119 doesn't work with Audirvana Plus 1.5.12
No Play option in iTunes integrated mode, highlighted song can be started in A+, but A+ crashes at the end of the song.
Re: New iTunes 12.4.0.119 doesn't work with Audirvana Plus 1.5.12
same here - since today Audirvana crashes after each song - same versions
This the other nice surprise from Apple (they don't give beta to developers for iTunes).
I've fixed this new compatibility issue in 2.5.1 I've just released.
Mac Mini > Audirvana Plus > AudioQuest Coffee USB > AMR DP-777 / exD DSD DAC > Viard Audio Design cables > Accuphase E-560 > Cabasse Sumatra
What do you think? Can we hope that the 1.5.12 will be able to work with the new version of iTunes?
Unless Apple reverts to the previous scripting interface, which is unlikely, only the updated Audirvana Plus will work iTunes integrated mode, so 2.5.1
Thank you for the answer.
It is a pity. Because the sound of the first and the second version is different.
gary.hf.chan
i got the problem of my 1.5.12 and stop at each song after played even in integrated mode. Any setting change can fix it? Will you have update on 1.5.x to fix it?
Audirvana Plus version 2 has been release for close to two years now.
The old version 1 continues to work well on the OS X & iTunes versions it has been developed for. It won't have new updates.
The version supporting El Capitan (and Mavericks, Yosemite) is the version 2, for which I offer free updates to continue to work well despite the unexpected changes done by Apple in its latest OS X & iTunes releases.
None of the software works with the new iTunes: Audirvana Plus. Amara, Bitperfect... This definitely is the fault of Apple as they do not support their developers. A shame!
Who is online
Users browsing this forum: No registered users and 1 guest
