Installation Instructions
Discover how to install Audirvana Plus 3 for Mac
1 – Get your Trial Version
In order to get the 15 days Free Trial Version, you need to click on the button “Download Free Trial” hereafter.
  • If you accept the terms of the License Agreement and click on the button “I fully agree with about above terms and Download now”, you can then download the Free Trial Version. After the download, you will get a .dmg file.
  • If you do not accept the terms of the License Agreement, click on the button “I disagree” and you will be redirected to Audirvana Homepage.
2 – Download Trial Version
To install Audirvana Plus 3 on your Mac, drag and drop the Audirvana Plus icon into the Applications folder,  following the arrow.
Once the installation is complete, you will find the Audirvana Plus icon on your desktop. Just double-click on it to launch the application.
This will give you access to the Full-Featured Free Trial Version.
3 – Quick Start of Audirvana Plus 3 Settings
4 – How to import your music into Audirvana Plus 3 ?
Do not hesitate to watch the short video in order to learn how to import your music into Audirvana Plus 3 for Mac.
Actually, you can import your music from your local files or by streaming your music through High Resolution Streaming Services:
  • TIDAL
  • Qobuz
  • HRA-Streaming (coming soon)
5 – Purchase of Audirvana Plus 3 for Mac
You’ve successfully used your trial version for 15 days and now you want to buy your Audirvana Plus 3 license key for Mac
Be aware that the Audirvana Plus 3 for Mac license key can be installed on 2 Mac computers :
  • for your exclusive use
  • not working simultaneously.
The license key can only be registered on a Mac computer if the trial version has been previously installed.
Following your purchase, you will receive from our reseller “2checkout-Avangate” an email titled “Your order on www.audirvana.com : Product and payment information” which contains your license key.
6 – Activate your License Key
If your trial period has expired, you should see the following popup :
Click on “Enter License Number”.
If you do not have the popup window at the start, use the “Download license file” option in the “Audirvana Plus” menu.
Enter your license key in the appropriate space.
You will then receive your confirmation message that the operation has been successfully completed.
And enjoy the Sound Quality of Audirvana Plus 3 for Mac.
