How to use Audirvana Plus ?
Discover how to easily benefit from all the features of your Music-player
Audirvana Plus : How to import your audio files ?
With AUDIRVANA PLUS, you can manage all your audio files, including your High Resolution audio files (FLAC, DSD, MQA..), in a dedicated “Library”. Once your music is imported in the “Library”, Audirvana Plus sorts all your audio files by Tracks (“View by Tracks”) and by Albums (“View by Albums”).
The following video explains “How to import your audio files into Audirvana Plus”.
Read more about Audio File Formats
Audirvana Plus : How to connect your Network Streamer ?
Audirvana Plus can send your audio files directly to your Network Player even when your Mac is not connected directly to your HiFi system.
The video below explains “How to connect your Network Player to Audirvana Plus”.
Read more about Audirvana Plus and network player
Audirvana Plus : How to Create and Manage Playlists ?
With Audirvana Plus, you can create your own Playlists in order to manage, store and classify your music the way you want.
The following video explains “How to create and manage Playlists in Audirvana Plus?”.
Read more about Playlists in Audirvana Plus
Audirvana Plus : How to Manage Metadata ?
Audirvana Plus gives you the ability to view and edit metadata for your songs and albums. These metadata are directly recorded in the audio file.
The following video explains “How to Manage Metada in Audirvana Plus”.
Read more about Metadata in Audirvana Plus
Audirvana Plus : Browse and Discover Music in TIDAL
Audirvana Plus integrates the HiRes streaming services TIDAL and Qobuz to give you the same stellar Sound Quality when playing streaming music as with your local files.
The following video explains “How to Browse & Discover Music with TIDAL in Audirvana Plus”.
