EXTENDED AUDIRVĀNA REMOTE EXPERIENCE
Take control of your music wherever you are at home with Audirvāna’s universal Remote. This app, designed for smartphones and tablets, is freely available, is the essential addition to the Audirvāna software and will allow you to control it remotely.
Free smartphone & tablet remote app
- Android
version available on the PlayStore
- iOS
version available on the AppStore
- Instant
connection over the same WiFi network than the computer
- Access
to all navigation features and settings
- Compatibility
with all versions of Audirvāna
Make yourself comfortable and enjoy your music without staying behind your computer.
Audirvāna Remote allows you to browse through all music libraries that are accessible from the app. You can create, rename and reorganize your playlists, and fine-tune the volume level, check and modify all your settings, and much more.
This mobile app is universal. In that manner, it will adapt the Audirvāna version of you are using.
Please note that the app plays as a a remote control, an interface that allows you to control the software. The music continues to be processed and played from the Core Player of the software, which is running on your computer. Indeed, these operations cannot yet be performed with the same playback quality from iOS or Android mobile operating systems.
Universal HD wireless connection
HD library manager
