Audirvāna Origin 3.0
Experience the all-new Allegro design & enjoy the new features of Audirvāna Origin 3.0
No subscription, no streaming service, only your library.
Audirvāna Origin offers you all the features you need to manage and play your local music library with the best sound quality.
It is available as a one-time purchase.
Signal Processing Suite
available for Audirvāna Origin
as an option
- 10-Band Parametric EQ
- Convolution Engine
- Crossfeed for Headphones
- Multichannel Balance
Server managing your local library
- All formats supported: WAV, AIFF, FLAC, ALAC, MQA and DSD etc.,
- No resolution limit other than the DAC itself: 32 bits and a sampling rate of 1411,2 kHz or DSD1024
- Virtually unlimited library size capability
- Synchronized with mulitple folders on internal storage, USB drives or NAS
- Apple Library synchronization
- Folder view showing the tree structure of your library
- Metadata edition & recovery (except cover arts)
Read more
Audirvāna also fetches your music where it is stored. Your stored files remain intact. Audirvāna creates its own database with metadata to navigate faster through your content. But regarding the audio, Audirvāna copies and processes the file you play on the fly without keeping it in memory. Only your files’ metadata can be modified from within the app if you choose to.
We have simplified the addition of music process in Audirvāna, with an easy drag and drop option of a file to listen to it (stored into a Temporary playlist).
For a more permanent addition, you can synchronize different folders containing your music from the ‘local’ menu in the settings. Audirvāna will then automatically update the library at each startup. Folders may be directly stored on your computer, or on an external hard drive connected via USB or a network, on a NAS for example.
If you are a Mac user, you can also synchronize your Apple Music library in the same manner.
Audirvāna performs an audio recognition of your local library (“audio fingerprinting”). This is done in the background and you can use Audirvāna normally and exit the application whenever you want. The scan will pick up where it left off before quitting.
If your library is large, this analysis can take quite a long time. But it is only done once when you first synchronize. It helps recognize your recordings to give you more information about your music and to offer you more relevant related music in your streaming service.
If you want, the ID matching this audio fingerprint can be added to your audio files’ metadata which will avoid repeating the scan if you install Audirvāna on another computer to play the same library.
Intuitive music browser with navigation filters, folder view and playlists panel
Enjoy our free Remote app
Control your music with our free mobile app Audirvāna Remote wherever you are at home.
Audirvāna Remote allows you to browse through all music libraries that are accessible from the app. You can create, rename and reorganize your playlists, and fine-tune the volume level, check and modify all your settings, and much more.
This mobile app is universal. In that manner, it will adapt the Audirvāna version of you are using.
Please note that the app is a remote control, an interface that allows you to control the software. The music continues to be processed and played from the Core Player of the software, which is running on your computer. Indeed, these operations cannot yet be performed with the same playback quality from iOS or Android mobile operating systems.
License Origin
One time purchase
149,99
vat
License without time limit
- Full access to Audirvāna Origin's features
- No library size limitation
- Two years min. OS compatibility updates
- At least one feature yearly updates until 2027
- Multiple installs (non-simultaneous use)
- Free smartphone Remote app
One time purchase
89.99
vat
Added to license without time limit
- 10 band EQ
- Convolution engine
- Crossfeed
- Output balance with gain & delay
- Accessible from Remote app
Bundle Offer
One time purchase
219.99
vat
License without time limit incl. option
- Full License Origin
- Signal Processing Suite
License Origin
One time purchase
149,99
vat
One time purchase
6,99
vat
- 10 band EQ
- Crossfeed
Bundle Offer
One time purchase
69,99
vat
Upgrade Origin
For Origin licenses bought
between March 2022 and June 2024
149,99
vat
- Allegro Design
- NAS and Linux compatibility
- 2 years OS compatibility updates extension
- Functional updates at least once a year until 2027
Bundle Offer
149,99
vat
- Upgrade Origin
