Universal HD wireless
connection
Mit Audirvana können Sie Ihre Musik drahtlos und ohne Qualitätsverluste auf Ihr System streamen. Die Software nutzt Chromecast und das Universal Plug n Play (UPnP)-Protokoll, das in mehr als 7 Milliarden Geräten weltweit verwendet wird. Wenn Ihr System eines davon ist, wählen Sie es aus der Liste der im Netzwerk sichtbaren Audiogeräte aus und starten Sie die Wiedergabe Ihrer Musik mühelos mit Audirvana.
Chromecast audio & upnp
- Automatic detection
of UPnP (or DLNA) compatible devices on the network
- Complete
operational protocol functions including gapless transitions and seek
- Double role
of the software as “control point” and ad hoc “media server”
- Chromescast
compatibility including for multi-room set ups
Wireless and flawless.
Audirvāna Connect allows you to deliver your music to your system wirelessly and without any loss of quality.
If your system is compatible, it will directly be visible among the available audio devices and you will be able select it and start playing your music.
Audirvāna now integrates Google cast wireless protocol – also known as Chromecast – and can send audio to any compatible device – or group of devices in multi-room mode – in lossless quality up to 96kHz / 24bits.
Audirvāna also uses Universal Plug & Play (UPnP / DLNA), available on in more than 7 billion devices worldwide.
It is an open and complete standard that guarantees a lossless transmission of data over a computer network (via a Wi-Fi wireless connection, or thru an Ethernet or PLC cable connection). This common language allows devices and programs to communicate together, in the best interest of users who do not have to change their entire system because they change one part of it.
In this configuration, a “media renderer”, which converts and plays music, fetches the files from a “media server” under the control of a “control point”, typically your computer. In order to ensure upstream decoding of the files, Audirvāna plays both the role of control point and ad hoc media server, i.e. it is seen by the renderer as the file provider, which enables it to perform the necessary operations upstream of playback.
In UPnP connection, the latency is higher than in USB. As a result, some real-time adjustments are not possible in this case, such as using the internal digital volume control, or real-time equalization in plugins.
