SIGNAL PROCESSING TOOLKIT
Audirvāna provides you with a digital signal processing toolkit that opens up numerous possibilities. You can adjust, personalize and optimize your listening experience according to both your desires and your system.
Internal digital volume control
A solution ready to take over
internal digital volume control
in addition to or instead of the volume of your audio device
Audio Plugins integration
A custom-made performance
for inserting serial plugins into the audio processing flow
Formats under MacOS and VST3 under Windows10
of using an equalizer for example or a convolution engine for the application of a room acoustic correction filter
Upsampling algorithms
Shift up a gear
to oversample all audio streams before playback
high-performance algorithms available: SOX and R8 Brain
settings of frequency multiples and filters
