Universal HD wireless connection
Audirvāna allows you to wirelessly stream your music to your system without any loss of quality. The software uses Chromecast and the Universal Plug n Play (UPnP) protocol, installed on over 7 billion devices worldwide. If your system is compatible, you can select it from the audio devices list available on your network and start playing your music effortlessly with Audirvāna.
Wireless and flawless
- Automatic detection
- Complete
operational protocol functions including gapless transitions and seek
- Double role
- Chromescast
compatibility including for multi-room set ups
Audirvāna Connect allows you to deliver your music to your system wirelessly and without any loss of quality.
If your system is compatible, it will directly be visible among the available audio devices and you will be able select it and start playing your music.
Audirvāna now integrates Google cast wireless protocol – also known as Chromecast – and can send audio to any compatible device – or group of devices in multi-room mode – in lossless quality up to 96kHz / 24bits.
Audirvāna also uses Universal Plug & Play (UPnP / DLNA), available on in more than 7 billion devices worldwide.
It is an open and complete standard that guarantees a lossless transmission of data over a computer network (via a Wi-Fi wireless connection, or thru an Ethernet or PLC cable connection). This common language allows devices and programs to communicate together, in the best interest of users who do not have to change their entire system because they change one part of it.
In this configuration, a “media renderer”, which converts and plays music, fetches the files from a “media server” under the control of a “control point”, typically your computer. In order to ensure upstream decoding of the files, Audirvāna plays both the role of control point and ad hoc media server, i.e. it is seen by the renderer as the file provider, which enables it to perform the necessary operations upstream of playback.
In UPnP connection, the latency is higher than in USB. As a result, some real-time adjustments are not possible in this case, such as using the internal digital volume control, or real-time equalization in plugins.
